The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
secd.asidtrans events
Creating your file...
Your file is ready
secd.asidTrans.invalidAsid
- Severity
ALERT
- Description
This message occurs when ONTAP® software cannot translate an abbreviated SID to a Windows SID. An abbreviated SID is an internal ID maintained by ONTAP. This failure can cause CIFS share access issues.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
For Vserver "%s", ONTAP could not translate an abbreviated SID to a Windows SID.
- Parameters
vserverName (STRING): Vserver associated with this operation.
