sfo.giveback events
sfo.giveback EMS events occur when ONTAP encounters issues associated with storage failover (SFO) giveback operations.
sfo.giveback.aborted.bdfu
- Severity
ERROR
- Description
This message occurs when giveback of storage failover (SFO) aggregates is aborted because the background disk firmware update either on the source node or destination node took more than 120 seconds to finish.
- Corrective Action
Rerun the "storage failover giveback" command.
- Syslog Message
Giveback is aborted: %s took more than 120 seconds to finish the background disk firmware update.
- Parameters
nodename (STRING): Node where the background firmware update took more than 120 seconds to finish.
sfo.giveback.aggregatesAbort
- Severity
INFORMATIONAL
- Description
This message occurs when a giveback of non-root aggregates is aborted by either another takeover or other conflicting operation.
- Corrective Action
(None).
- Syslog Message
Giveback of non-root aggregates to node %s was aborted due to another takeover or other conflicting operation. "override-vetoes" was set to %s, "require-partner-waiting" was set to %s, and "only_newly_acquired" was set to %s.
- Parameters
partnerName (STRING): Partner name.
override_vetoes (STRING): Flag that indicates whether the system overrides veto checks during a giveback operation. This flag corresponds to the "-override-vetoes" parameter of the "storage failover giveback" command. When set to true, it might result in some veto checks made by subsystems on the source node getting overridden.
require_partner_waiting (STRING): Flag that indicates whether, during a giveback, the storage is given back regardless of whether the partner node is available to take back the storage. This flag corresponds to the "-require-partner-waiting" parameter of the "storage failover giveback" command. When set to true, it might result in the giveback proceeding even if the destination node is not ready to receive the aggregate being migrated.
only_newly_acquired (STRING): Flag that indicates whether, during a giveback, only aggregates acquired during the last takeover will be given back.
sfo.giveback.attemptExceeded
- Severity
ALERT
- Description
This message occurs when the number of attempts for automatic giveback of storage failover (SFO) aggregates exceeds the maximum allowed.
- Corrective Action
Use the "storage failover show-giveback" command to identify the subsystems that failed the giveback. Follow the corrective action specified in the EMS message displayed by those subsystems. Retry giveback by using the "storage failover giveback" command.
- Syslog Message
Attempts for automatic giveback of SFO aggregates exceeded the maximum number (%d) of allowed attempts.
- Parameters
attempts (INT): Maximum number of automatic giveback attempts allowed.
sfo.giveback.complete
- Severity
INFORMATIONAL
- Description
This message occurs when a giveback of storage failover (SFO) aggregates to the SFO partner controller finishes.
- Corrective Action
(None).
- Syslog Message
Giveback of SFO aggregates to partner (%s) is complete. override-vetoes: %s, require-partner-waiting: %s, and only_newly_acquired: %s.
- Parameters
partnerName (STRING): Partner's name.
override_vetoes (STRING): Flag that indicates whether the system overrides vetoes during a giveback operation. This flag corresponds to the "-override-vetoes" parameter of the "storage failover giveback" command. When set to true, it might result in some veto checks made by subsystems on the source node getting overridden.
require_partner_waiting (STRING): Flag that indicates whether, during a giveback, the storage is given back regardless of whether the partner node is available to take back the storage or not. This flag corresponds to the "-require-partner-waiting" parameter of the "storage failover giveback" command. When set to true, it might result in the giveback proceeding even if the destination node is not ready to receive the aggregate being migrated.
sfo.giveback.delayed.bdfu
- Severity
INFORMATIONAL
- Description
This message occurs when giveback of storage failover (SFO) aggregates is delayed because a background disk firmware update is in progress either on the source node or destination node. If the update does not finish within 120 seconds, giveback will be aborted.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
nodename (STRING): Node where the background firmware update is in progress.
sfo.giveback.failed
- Severity
ALERT
- Description
This message occurs when giveback of the partner's Storage Failover (SFO) aggregate fails.
- Corrective Action
Other error messages indicate the exact cause of failure along with the corrective action.
- Syslog Message
Giveback of aggregate %s failed due to %s.
- Parameters
aggr (STRING): Name of the aggregate that was not given back.
msg (STRING): Error that prevented giveback.
sfo.giveback.OpFailed
- Severity
ALERT
- Description
This message occurs when the Storage Failover (SFO) phase of giveback fails.
- Corrective Action
Refer to other generated error messages to identify the exact cause of failure and the corrective action.
- Syslog Message
SFO phase of giveback failed by node %s because %s.
- Parameters
node (STRING): Name of the node that failed giveback.
sfo.giveback.postMigrNotOk
- Severity
ALERT
- Description
This message occurs when the specified subsystem encounters an error during the post-migration phase of the giveback operation.
- Corrective Action
Check the event log for a subsystem-specific reason as to why the subsystem failed the post-migration phase of the giveback operation. The corrective action is subsystem-specific and is detailed in the corrective action portion of the message. Follow the corrective action specified by that message.
- Syslog Message
The giveback operation of '%s' encountered an error during post-migration processing. The error was encountered by the subsystem '%s'.
- Parameters
aggr (STRING): Name of the aggregate on which the subsystem attempted the giveback operation.
subsystem (STRING): Name of the subsystem that failed the post-migration phase of the giveback operation.
sfo.giveback.spares.failed
- Severity
ALERT
- Description
This message occurs when giveback of the partner's storage failover (SFO) spares fails.
- Corrective Action
Try the SFO giveback again.
- Syslog Message
Giveback of spares failed due to %s.
- Parameters
msg (STRING): Error that prevented giveback of SFO spares.
