smbc.avail events
smbc.avail.aufoDisabled
- Severity
ERROR
- Description
This message occurs when the primary-bias state is set for the secondary endpoints of the SnapMirror Business Continuity (SMBC) relationships because both of the SMBC clusters lose connectivity to the ONTAP Mediator. It prevents an automatic unplanned failover operation on the secondary endpoints.
- Corrective Action
Check the network connection and restore the access to the ONTAP Mediator.
- Syslog Message
Primary-bias state is set for the secondary endpoints of the SMBC relationships. ONTAP Mediator IP: "%s", Peer cluster: "%s".
- Parameters
ipAddress (STRING): ONTAP Mediator IP address.
peerCluster (STRING): Peer cluster name.
smbc.avail.aufoEnabled
- Severity
NOTICE
- Description
This message occurs when the primary-bias state is cleared for the secondary endpoints of the SnapMirror Business Continuity (SMBC) relationships. It resumes the ONTAP Mediator assisted automatic unplanned failover operation on secondary endpoints.
- Corrective Action
(None).
- Syslog Message
Primary-bias state is cleared for the secondary endpoints of the SMBC relationships. ONTAP Mediator IP: "%s", Peer cluster: "%s".
- Parameters
smbc.avail.primaryBias
- Severity
ERROR
- Description
This message occurs when the primary-bias state is set for the primary endpoints of the SnapMirror Business Continuity (SMBC) relationships because both of the SMBC clusters lose connectivity to the ONTAP Mediator. It allows primary endpoints to drive the consensus locally without depending on the ONTAP Mediator.
- Corrective Action
- Syslog Message
Primary-bias state is set for the primary endpoints of the SMBC relationships. ONTAP Mediator IP: "%s", Peer cluster: "%s".
- Parameters
smbc.avail.primaryBiasReset
- Severity
NOTICE
- Description
This message occurs when the primary-bias state is cleared for the primary endpoints of the SnapMirror Business Continuity (SMBC) relationships. It resumes the three-way quorum involving the ONTAP Mediator and peer cluster to derive consensus.
- Corrective Action
(None).
- Syslog Message
Primary-bias state is cleared for the primary endpoints of the SMBC relationships. ONTAP Mediator IP: "%s", Peer cluster: "%s".
- Parameters
