ONTAP EMS reference
smbc.pfo events
smbc.pfo EMS events occur when ONTAP encounters issues associated with SnapMirror® active sync planned failover operations.
smbc.pfo.completed
Severity
NOTICE
This message occurs when the SnapMirror® Business Continuity (SMBC) planned failover operation completes.
Corrective Action
(None).
Syslog Message
SMBC planned failover operation completed. Destination path: %s.
dstpath (STRING): Path name of the destination group of the SMBC relationship.
smbc.pfo.failed
Severity
ERROR
This message occurs when the SnapMirror® Business Continuity (SMBC) planned failover operation fails.
Corrective Action
Determine the cause of the failure by using the "snapmirror failover show -fields error-reason" command. After addressing the cause, retry the "snapmirror failover start -destination-path destination_path" command.
Syslog Message
SMBC planned failover operation failed. Destination path: %s.
smbc.pfo.io.outage.compl.dst
Severity
NOTICE
This message occurs when the secondary (erstwhile) side conversion completes after a planned failover operation of a SnapMirror Business Continuity (SMBC) relationship.
Corrective Action
(None).
Syslog Message
In the planned failover of the SMBC relationship with destination path %s and relationship-ID %s, the destination side I/O disruption started at %s and lasted for %u msecs.
dstpath (STRING): Destination path of the SMBC relationship.
cg_rel_id (STRING): ID of the SMBC relationship.
start_time (STRING): I/O disruption start time.
latency (LONGINT): I/O disruption window (msecs).
smbc.pfo.io.outage.compl.src
Severity
NOTICE
This message occurs when the primary (erstwhile) side conversion completes after a planned failover operation of a SnapMirror Business Continuity (SMBC) relationship and IO outage completes as the Report Target Port Group(RTPG) is consistent.
Corrective Action
(None).
Syslog Message
In the planned failover of the SMBC relationship with destination path %s and relationship-ID %s, the source side I/O disruption started at %s and lasted for %u msecs.
smbc.pfo.start
Severity
NOTICE
This message occurs when the SnapMirror® Business Continuity (SMBC) planned failover operation starts.
Corrective Action
(None).
Syslog Message
SMBC planned failover operation started. Destination path: %s.
