smc.vlt events
smc.vlt EMS events occur when the transfer for the SnapVault® relationship replicating the read-only source volume fails because the SnapMirror® policy prevents it from transferring the exported snapshot from the source.
smc.vlt.cascade.xfer.fail
- Severity
ERROR
- Description
This message occurs when the transfer for the SnapVault® relationship replicating the read-only source volume fails because the SnapMirror® policy prevents it from transferring the exported Snapshot® copy from the source. Generally this happens when the "keep" value of the rule associated with the SnapMirror label of the exported Snapshot copy is reached and the "preserve" flag is set to "true".
- Corrective Action
Modify the rule for the SnapMirror policy associated with the SnapMirror label of the exported Snapshot copy on the source volume and either set the "preserve" flag to "false" or increase the "keep" count.
- Syslog Message
Unable to transfer any Snapshot copies to %s because the exported Snapshot copy %s with snapmirror-label %s has a rule whose "keep" value has been reached and the "preserve" flag is set to "true".
- Parameters
dst_path (STRING): Destination volume of the SnapVault relationship.
snap_name (STRING): Name of the exported Snapshot copy on the source volume.
snapmirror_label (STRING): SnapMirror label associated with the exported Snapshot copy.
