ONTAP EMS reference
sms.resync events
sms.resync EMS events occur when a resynchronize operation between the source volume and destination volume fails.
sms.resync.attempt.failed
Severity
ERROR
This message occurs when a resynchronize operation between the source volume and destination volume fails. The SnapMirror® Sync relationship is in "out-of-sync" status. Data protection is impacted.
Corrective Action
Monitor SnapMirror Sync status using the "snapmirror show" command. If the auto-resync attempts fail, bring the relationship back to "in-sync" status manually by using the "snapmirror resync" command.
Syslog Message
Resynchronize operation between source volume "%s" and destination volume "%s" with relationship UUID "%s" has failed. The next auto-resync will be attempted after "%d" mins.
srcpath (STRING): Path name of the source volume of the SnapMirror relationship.
dstpath (STRING): Path name of the destination volume of the SnapMirror relationship.
relationship_id (STRING): Relationship UUID.
next_resync_interval (INT): Interval after which the next resync will be attempted.
