ONTAP EMS reference
vifmgr.bgp events
vifmgr.bgp.connected
Severity
NOTICE
This message occurs when Logical Interface Manager (VifMgr) connects to BGP daemon.
Corrective Action
(None).
Syslog Message
VifMgr connected to BGP daemon on the node.
(None).
vifmgr.bgp.defaults.upgrade
Severity
NOTICE
This message occurs when the Autonomous System Number (ASN) in "bgp defaults" changes from the reserved number to the default number (65501).
Corrective Action
(None).
Syslog Message
Autonomous System Number (ASN) in "bgp defaults" was changed from the reserved number (%d) to the default number (65501).
old_asn (INT): Reserved Autonomous System Number (ASN) in "bgp defaults" before it is changed.
vifmgr.bgp.disconnected
Severity
ERROR
This message occurs when the connection between the Logical Interface Manager (VifMgr) and the BGP daemon is broken. The connection is automatically reestablished. In case the connection is not reestablished, any Virtual IP LIFs might fail over to another node.
Corrective Action
Verify that the BGP daemon restarted by looking for the "vifmgr.bgp.connected" event. If the BGP daemon fails to restart, or if the condition persists, contact NetApp technical support.
Syslog Message
The connection between VifMgr and the BGP daemon on the node is broken.
(None).
vifmgr.bgp.vserverDown
Severity
NOTICE
This message occurs when a BGP down event is received for a system Vserver. Any VIP LIFs in the associated data Vservers can no longer handle network traffic.
Corrective Action
(None).
Syslog Message
VifMgr received a Vserver BGP down event for Vserver %s in IPspace %s.
vserver (STRING): Name of the Vserver.
ipspace (STRING): Name of the IPspace where the Vserver resides.
vifmgr.bgp.vserverUp
Severity
NOTICE
This message occurs when a BGP up event is received for a system Vserver. Any VIP LIFs in the associated data Vservers can now handle network traffic.
Corrective Action
(None).
Syslog Message
VifMgr received a Vserver BGP up event for Vserver %s in IPspace %s.
