ONTAP EMS reference
vifmgr.skippingl2pingtest events
vifmgr.skippingl2pingtest EMS events occur when the number of local ports in the given broadcast domain exceeds the threshold for a node and, as a result, the l2_reachability health monitor has omitted checking ports in that broadcast domain.
vifmgr.skippingL2PingTest
Severity
NOTICE
This message occurs when the number of local ports in the given broadcast domain exceeds the threshold for a node and, as a result, the l2_reachability health monitor has omitted checking ports in that broadcast domain. If any local ports in this broadcast domain experience Layer 2 connectivity problems, they are not marked as degraded and no EMS messages related to the Layer 2 connectivity health of those ports is generated. LIFs hosted on those port are not automatically migrated to healthy ports because of Layer 2 connectivity issues.
Corrective Action
This is not a misconfiguration; however, including fewer than the specified threshold ports in the broadcast domain enables the l2_reachability health monitor to check the health of the ports in that broadcast domain.
Syslog Message
Skipping l2_reachability health monitor check for ports belonging to broadcast domain %s on node %s as the number of local ports (%u) belonging to this broadcast domain exceeds the threshold (%u) for which l2_reachability health monitor check can efficiently run.
bcDomainName (STRING): Name of the broadcast domain for which the l2_reachability health monitor check is being skipped.
nodeName (STRING): Name of the node for which the number of local ports in the given broadcast domain exceeds the threshhold.
numLocalPorts (INT): Number of local ports in the specified broadcast domain.
maxLocalPorts (INT): Threshold value for the maximum number of local ports in a broadcast domain for which the l2_reachability health monitor check can run.
