vm.dev events
vm.dev EMS events occur when ONTAP encounters issues associated with disk I/O performance or device write-protection on virtual platforms.
vm.dev.diskSlowIO
- Severity
ERROR
- Description
This message occurs when Data ONTAP® is running on a virtual platform, and slow I/O is detected.
- Corrective Action
Collect virtual platform logs and trigger a performance archive AutoSupport® messsage with the "autosupport invoke-performance-archive" command, and then contact NetApp technical support for troubleshooting assistance.
- Syslog Message
The %s request on disk %s took %u seconds (data size %u bytes, threshold %u seconds).
- Parameters
op (STRING): Read/write operation.
disk (STRING): Disk name.
secUsed (INT): Seconds the I/O spent.
size (INT): Data size.
secLimit (INT): Threshold in seconds that triggers the warning.
vm.dev.writeprotected
- Severity
ERROR
- Description
This message occurs when ONTAP® software is running on a virtual platform, and a write-protected device is detected. The device is not presented to ONTAP.
- Corrective Action
Detach the device, and then reattach the device as writable.
- Syslog Message
The device %s is write-protected and is not presented to ONTAP.
- Parameters
device (STRING): Device name.
