ONTAP EMS reference
vnm.dataip events
vnm.dataip EMS events occur when ONTAP encounters issues associated with a data IP address being added to or removed from a node.
vnm.dataip.added
Severity
NOTICE
This message occurs when a data IP address is being added to a node. Data access through this IP address is now available.
Corrective Action
(None).
Syslog Message
Data IP address %s is being added to a node %s (ID: %u, Uuid: %s).
dataip (STRING): The IP address that is being added.
nodename (STRING): Name of the node to which the data IP is being added.
nodeid (INT): Unique identifier of the node to which the data IP is being added.
nodeUuid (STRING): Universal unique identifier of the node to which the data IP is being added.
vnm.dataip.removed
Severity
NOTICE
This message occurs when a data IP address is being removed from a node. Data access through this IP address is now unavailable.
Corrective Action
(None).
Syslog Message
Data IP address %s is being removed from node %s (ID: %u, Uuid: %s).
dataip (STRING): The IP address that is being removed.
nodename (STRING): Name of the node from which the data IP is being removed.
nodeid (INT): Unique identifier of the node from which the data IP is being removed.
nodeUuid (STRING): Universal unique identifier of the node to which the data IP is being removed.
