vserver.rbac events
Creating your file...
vserver.rbac.alias.command
- Deprecated
ONTAP now directly creates a role entry on the target of the alias.
- Severity
ERROR
- Description
This message occurs when a custom role associated with a Storage Virtual Machine (SVM) has an aliased command directory associated with it. SVM custom roles must be associated with actual command directories and commands, not aliases to them. The aliased commands associated with SVM custom roles will not be available under SVM context.
- Corrective Action
Delete the role on the SVM, and then re-create it using the actual command.
- Syslog Message
The custom role %s is associated with alias command - %s on SVM %s. Create role with actual command - %s.
- Parameters
role_name (STRING): Name of the role for which creation failed.
alias_name (STRING): Name of the alias that is associated with the role.
vserver_name (STRING): Name of the SVM.
non_alias_name (STRING): Name of the actual command.
vserver.rbac.replicateRole
- Severity
ERROR
- Description
This message occurs when replication of a role is failed on a Vserver because the command directory associated with it is an alias.
- Corrective Action
Delete the role on the source Vserver, and then re-create it using the non-alias target. Then retry the operation again.
- Syslog Message
Failed to replicate the role %s associated with the alias %s on Vserver %s.
- Parameters
vserver_name (STRING): Name of the Vserver.
