wafl.aggrtrans events
wafl.aggrtrans EMS events occur when ONTAP encounters issues associated with aggregate transition operations from 7-Mode to clustered Data ONTAP.
wafl.aggrtrans.corrupted
- Severity
ALERT
- Description
This message occurs when an aggregate transition operation encounters a corrupted aggregate.
- Corrective Action
Delete the corrupted aggregate in maintenance mode. Alternatively, return the disks to a 7-Mode environment to fix the corrupted aggregate.
- Syslog Message
Aggregate transition encountered a corrupted aggregate %s.
- Parameters
aggrname (STRING): Name of the aggregate.
wafl.aggrtrans.dirtyFS
- Severity
NOTICE
- Description
This message occurs when an aggregate transition operation fails because the aggregate was not cleanly shut down.
- Corrective Action
Retry the aggregate transition to bypass this specific error. Alternatively, return the disks to a 7-Mode environment, cleanly shut down the system, and then try the transition again.
- Syslog Message
Aggregate %s was not cleanly shut down and could not be transitioned.
- Parameters
wafl.aggrtrans.dirtyFS.cont
- Severity
NOTICE
- Description
This message occurs when an aggregate transition continues to operate on an aggregate that was not cleanly shut down.
- Corrective Action
(None).
- Syslog Message
Aggregate %s was not cleanly shut down and is continuing transition.
- Parameters
wafl.aggrtrans.outofspace.nodereboot
- Severity
ALERT
- Description
This message occurs when a transitioned aggregate reaches a space limitation during the precommit phase and cannot be taken offline. The node is automatically rebooted to ensure that data integrity is preserved. After the reboot, the aggregate is online and its FlexVol® volumes are offline.
- Corrective Action
Add disks to the aggregate to ensure that enough free space is available. Alternatively, commit the current transition session.
- Syslog Message
Transitioned aggregate %s is critically low on available space, initiating node reboot.
- Parameters
wafl.aggrtrans.outofspace.normal
- Severity
NOTICE
- Description
This message occurs when a previously full transitioned aggregate contains enough free space and is back to normal operation.
- Corrective Action
(None).
- Syslog Message
Transitioned aggregate %s now contains enough free space and is now back to normal.
- Parameters
wafl.aggrtrans.outofspace.offline
- Severity
EMERGENCY
- Description
This message occurs when a transitioned aggregate reaches a space limitation during the precommit phase and is taken offline.
- Corrective Action
- Syslog Message
Transitioned aggregate %s is critically low on available space, going offline.
- Parameters
wafl.aggrtrans.outofspace.remount.needed
- Severity
NOTICE
- Description
This message occurs when a previously full transitioned aggregate is online and must be remounted to bring its volumes back online.
- Corrective Action
Take offline the transitioned aggregate, and then bring online the aggregate again to bring its volumes back online.
- Syslog Message
Transitioned aggregate %s must be remounted (offline and online) to bring its volumes back online.
- Parameters
wafl.aggrtrans.outofspace.warn
- Severity
ERROR
- Description
This message occurs when a transitioned aggregate is low on free space. The message is periodically displayed before the aggregate goes offline due to being out of space.
- Corrective Action
Add disks to the aggregate to resume normal operations. Alternatively, commit the current transition session.
- Syslog Message
Pre-commit transitioned aggregate %s is low on free space at about %d percent used.
- Parameters
percent (INT): Percentage of aggregate that is used.
wafl.aggrtrans.revert.to.snap
- Severity
NOTICE
- Description
This message occurs when an aggregate transition operation fails because the aggregate is set to revert to a Snapshot copy.
- Corrective Action
Return the disks to a 7-Mode environment, bring the aggregate online to finish restoring to the Snapshot® copy, and then try the transition again.
- Syslog Message
Aggregate %s is reverting to a Snapshot copy and cannot be transitioned.
- Parameters
wafl.aggrtrans.snap.delErr
- Severity
ERROR
- Description
This message occurs when an aggregate transition commit operation fails to delete the pinned Snapshot® copy.
- Corrective Action
Manually delete the pinned Snapshot copy using the node scoped command "snap delete -A". If manual deletion fails, contact technical support.
- Syslog Message
Aggregate transition commit operation fails to delete the pinned Snapshot® copy "%s" on aggregate %s. Error: %s.
- Parameters
name (STRING): Name of the Snapshot copy.
err (STRING): Error description.
wafl.aggrtrans.snapshot.32b
- Severity
ERROR
- Description
This message occurs when an aggregate transition fails due to detection of a 32-bit Snapshot copy on the transition aggregate.
- Corrective Action
Retry aggregate transition using "-ignore-errors" parameter to automatically delete all the 32-bit Snapshot copies as part of aggregate transition.
- Syslog Message
Aggregate transition failed due to unsupported 32-bit snapshots on aggregate %s uuid %s.
- Parameters
aggruuid (STRING): Unique identifier of the aggregate.
