wafl.compress events
wafl.compress.cde.event
Severity
NOTICE
This message occurs when WAFL compression on container file level is enabled or disabled on a volume.
Corrective Action
(None).
Syslog Message
WAFL container compression state changed in %s "%s" to "%s".
volume_identifier (STRING): Volume identifier.
volume (STRING): Volume name.
message (STRING): Whether enable or disable.
wafl.compress.enable.failed
Severity
INFORMATIONAL
This event is issued when FAS compression can not be enabled on a volume. The following reasons might be causing the problem: FAS compression might not be supported on the software release you're running; the volume is not a flexible volume or it is a root volume or snaplock volume; the compression/de-compression scanner is already active; or a clone operation is already underway.
Corrective Action
(None).
Syslog Message
Compression could not be enabled on volume "%s" at this time. Check the volume configuration and retry.
vol (STRING): Volume name.
wafl.compress.fail.rootVol
Severity
NOTICE
This message occurs when an administrator attempts to enable compression on the root volume. Compression cannot be enabled on the root volume.
Corrective Action
(None).
Syslog Message
'%s' is the root volume and compression cannot be enabled on the root volume.
wafl.compress.mark.cg.bad.hw
Severity
ALERT
This message occurs when the FAS compression writes bad blocks for an inconsistent or corrupted compression group due to hardware errors.
Corrective Action
Restore the corrupted file from the Snapshot copy, or contact NetApp technical support
Syslog Message
FAS compression: Writing bad blocks, at fbn:%llu level:%u in %s inode (fileid:%d snapid:%u) in volume %s%s%s%s.
fbn (LONGINT): File block number.
level (INT): Buffer level.
ino_type (STRING): Inode type
fileid (INT): Identifying number for the suspect inode.
snapid (INT): Snapshot(tm) copy identifier: (0) - active file system (non-zero) - refers to Snapshot copy
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Uniquely identifies the volume in cases where the volume name itself is insufficient.
wafl.compress.mark.cg.bad.sw
Severity
ERROR
This message occurs when the FAS compression writes bad blocks for an inconsistent or corrupted compression group due to software errors.
Corrective Action
Syslog Message
wafl.compress.scan.checkpoint.deleted
Severity
NOTICE
This event is generated when the FAS compression of existing data for volume deletes checkpoint.
Corrective Action
(None).
Syslog Message
vol compress: Checkpoint deleted for compression of existing data for volume "%s%s%s".
vol (STRING): Name of the compressed volume.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
