acp.init events
Creating your file...
acp.init.configIP
- Severity
ERROR
- Description
This message occurs when ONTAP® software cannot configure the Ethernet port designated for the Alternate Control Path (ACP) with 30 seconds, and marks the ACP as inactive.
- Corrective Action
Verify the connection to the disk shelf ACP port, and make sure that it is not connected to a public network. Try plugging it into another Ethernet port with no devices.
- Syslog Message
Could not configure the ACP Ethernet port within 30 seconds.
- Parameters
(None).
acp.init.netmask
- Severity
INFORMATIONAL
- Description
This message occurs during initialization state, when the Alternate Control Path (ACP) Administrator netmask was configured incorrectly. The system sets the netmask to a default value.
- Corrective Action
(None).
- Syslog Message
Setting ACP Administrator netmask value to %s (reason: %s).
- Parameters
value (STRING): Default netmask.
reason (STRING): Reason to choose the default.
acp.init.ssl
- Deprecated
Deprecated as of ONTAP® version 9.2. The ACP process was never really responsible for initializing SSL, and has not tried to do so for a very long time.
- Severity
ERROR
- Description
This message occurs when the Alternate Control Path (ACP) process cannot initialize the underlying Secure Socket Library (SSL). The ACP Administrator will be inactive.
- Corrective Action
(None).
- Syslog Message
Could not initialize SSL.
- Parameters
(None).
