callhome.jpc events
Creating your file...
callhome.jpc.selection.fail
- Severity
ALERT
- Description
This message occurs when the Kernel Cluster Services (KCS) / Cluster Transaction Manager (CTRAN) detects that the algorithm to reselect the Join Proposal Coordinator (JPC) is failing repeatedly. The JPC is reselected when the node that hosted the JPC goes out of quorum. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
- Corrective Action
Call NetApp technical support immediately for further assistance.
- Syslog Message
Call home for JOIN PROPOSAL COORDINATOR SELECTION FAILING.
- Parameters
subject (STRING): AutoSupport subject or title for this event.
epoch (STRING): Identifying tag for multi node ASUP.
