cf.ic events
Creating your file...
cf.ic.cc.config.changed
- Severity
NOTICE
- Description
This message occurs when the controller configuration is changed from a single enclosure HA configuration to a dual enclosure HA configuration.
- Corrective Action
If the controller is part of a dual enclosure HA configuration, make sure that the psm-cc-config? environment variable is unset and reboot.
- Syslog Message
HA interconnect: Controller configuration was changed from single enclosure HA configuration to dual enclosure HA configuration.
- Parameters
(None).
cf.ic.clientinitFailed
- Severity
ERROR
- Description
This message occurs when the interconnect client fails to initialize due to remote VI setup failure.
- Corrective Action
Reboot the controller. Contact NetApp technical support if the problem persists.
- Syslog Message
HA interconnect: Initialization failure for %s client.
- Parameters
client (STRING): Name of the client that failed to initialize.
cf.ic.disabled
- Severity
ERROR
- Description
This message occurs when the HA interconnect is disabled by the ic-type environment variable.
- Corrective Action
Either remove the HA interconnect from the controller or change the ic-type environment variable.
- Syslog Message
HA interconnect: Card in slot %d has been disabled because of the ic-type environment variable.
- Parameters
slot (INT): Slot that the interconnect is in.
cf.ic.driver.flush.idWarn
- Severity
NOTICE
- Description
This message occurs when the HA interconnect cannot process a flush request for a particular driver I/O request.
- Corrective Action
(None).
- Syslog Message
HA interconnect: Flush %s failed for channel %d and ID %d.
- Parameters
s (STRING): Name of the error.
nvidx (INT): Interconnect channel.
wrid (INT): Work request ID.
cf.ic.failed.memReg
- Severity
INFORMATIONAL
- Description
This message occurs when memory registration fails.
- Corrective Action
(None).
- Syslog Message
HA interconnect: Memory registration operation failed at %d.
- Parameters
source (INT): Source for the memory operation.
cf.ic.flush.ACKWarn
- Severity
NOTICE
- Description
This message occurs when the HA interconnect cannot send acknowledgments through its completion channel.
- Corrective Action
(None).
- Syslog Message
HA interconnect: Flush completion %s error.
- Parameters
cf.ic.flush.MemError
- Severity
ERROR
- Description
This message occurs during boot time initialization, when the HA interconnect encounters an error with memory registration or allocation.
- Corrective Action
Reboot the controller to restart the HA interconnect. Contact NetApp technical support if the problem persists.
- Syslog Message
HA interconnect: Flush memory %s error.
- Parameters
cf.ic.flush.oodIinitFailed
- Severity
ERROR
- Description
This message occurs when there is a failure in the initialization of a NIC to enable out-of-order delivery on the HA interconnect.
- Corrective Action
Reboot the controller to enable HA interconnect flushing. Contact NetApp technical support if the problem persists.
- Syslog Message
HA interconnect: Flush out-of-order delivery initialization failed.
- Parameters
(None).
cf.ic.heartBeatFailed
- Severity
ERROR
- Description
This message occurs when heartbeats cannot be sent or received over the HA interconnect.
- Corrective Action
Verify that both controllers in the HA pair are operational. If this message persists, disable and reenable the links one at a time by using the (privilege: advanced) "system ha interconnect link off" and "system ha interconnect link on" commands.
- Syslog Message
HA interconnect: Heartbeat failed.
- Parameters
(None).
cf.ic.initFailed
- Severity
ERROR
- Description
This message occurs when the driver fails to find an HA interconnect adapter or the interconnect is nonfunctional.
- Corrective Action
Verify that the High Availability interconnect card is present and operational on the system. Reboot the controller. Contact NetApp technical support if this problem persists.
- Syslog Message
HA interconnect: Unable to initialize process.
- Parameters
(None).
cf.ic.non.cc.config.changed
- Severity
NOTICE
- Description
This message occurs when the controller configuration is changed from a dual enclosure HA configuration to a single enclosure HA configuration.
- Corrective Action
If the controller is part of single enclosure HA configuration, make sure that that the other controller is physically present in the chassis and that the psm-cc-config? environment variable is set to true, and then reboot.
- Syslog Message
HA interconnect: Controller configuration was changed from dual enclosure HA configuration to single enclosure HA configuration.
- Parameters
(None).
cf.ic.notifyTimeout
- Severity
NOTICE
- Description
This message occurs when data transfer over the HA interconnect times out.
- Corrective Action
(None).
- Syslog Message
HA interconnect: %s transfer timed out.
- Parameters
qp_name (STRING): Queue-pair name.
cf.ic.portsCrossConnected
- Severity
ALERT
- Description
This message occurs when the HA interconnect driver determines that the ports between this controller and its partner are cross-connected.
- Corrective Action
Connect port 1 on this controller to port 1 on the partner, and connect port 2 on this controller to port 2 on the partner. If the interconnect cables have serial number tags on both ends, use the serial numbers to verify that the ports are properly connected. If the interconnect cables do not have serial number tags, disconnect one of the HA interconnect ports from one of the controllers. The LEDs of this port and one of the ports on the partner turn off. If the two ports have different port numbers, the cables are cross-connected. Reversing the connection on one of the controllers rectifies the problem.
- Syslog Message
HA interconnect: Port %d of this controller seems to be connected to port %d on the partner.
- Parameters
localPort (INT): Local port number.
remotePort (INT): Remote port number.
cf.ic.probe.error
- Severity
ALERT
- Description
This event is generated when we fail to detect an High Availability (HA) interconnect communication device during system initialization. If this error occurs, internode communication within the HA pair is down.
- Corrective Action
Examine the logs for messages regarding the HA interconnect. Resolve the HA interconnect problems.
- Syslog Message
Failover monitor: no interconnect found WARNING: Failover monitor operating in degraded mode
- Parameters
errorCode (INT): The internal error code
cf.ic.sbb
- Severity
NOTICE
- Description
This message occurs when a system SBB (Storage Bridge Bay) Compatibility event occurs. SBB Compatibility events determine the presence or absence of the HA partner controller on some platforms.
- Corrective Action
(None).
- Syslog Message
HA interconnect: SBB Compatibility Event. %s
- Parameters
event_description (STRING): Presence or absence of the partner controller and what action has been taken on the interconnect device.
cf.ic.xferTimedOut
- Severity
ERROR
- Description
This message occurs when data transfer over the HA interconnect times out. This is usually seen when the interconnect link goes down. It can also be encountered when the interconnect hardware, firmware, or driver experiences a hang.
- Corrective Action
- Syslog Message
- Parameters
qp_name (STRING): Name of the connection queue-pair that timed out.
cf.ic.xferTimedOutVSA
- Severity
NOTICE
- Description
This message occurs when data transfer over the high-availability (HA) interconnect times out on virtual platforms. This is usually seen when the underlying network is busy or the system is operating under heavy load.
- Corrective Action
- Syslog Message
- Parameters
