clam.invalid events
Creating your file...
clam.invalid.config
- Severity
ERROR
- Description
This message occurs when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) determines that the local node is in an invalid configuration for providing CLAM functionality.
- Corrective Action
Take one or more of the following actions, as appropriate: - Enable failover on the node by running the 'storage failover modify -node node_name -enabled true' command. - If there is a version incompatibility between the local node and the other nodes in the cluster, upgrade the nodes as needed.
- Syslog Message
Local node (name=%s, id=%llu) is in an invalid configuration for providing CLAM functionality. CLAM cannot determine the identity of the HA partner.
- Parameters
localhostname (STRING): Host name of the local node.
localnodeid (LONGINT): Node ID of the local node.
