clam.voting events
Creating your file...
Your file is ready
clam.voting.state.change
- Severity
INFORMATIONAL
- Description
This message occurs when the Kernel Cluster Services Connectivity, Liveliness, Availability Monitor (CLAM) detects that the voting state of the node changed.
- Corrective Action
(None).
- Syslog Message
CLAM on node (name=%s, ID=%llu) has %s voting for its HA partner node(name=%s, ID=%llu).
- Parameters
local_hostname (STRING): Host name of the local node.
localId (LONGINT): Node ID of the local node.
state (STRING): New voting state of the node.
partner_hostname (STRING): Host name of the HA partner node.
partnerId (LONGINT): Node ID of the HA partner node.
