config.mirrornotmultipath events
config.MirrorNotMultiPath
Severity
ERROR
This message occurs when a disk is not multipathed but synchronous mirroring is enabled.
Corrective Action
Multipath the disk shelf stack by also attaching it to a different host adapter via the other shelf module in each disk shelf in the stack.
Syslog Message
Disk %s and other disks on this loop/domain are not multipathed and should be for synchronous mirroring configuration.
disk (STRING): Name of the disk.
