config.sameswitchwarn events
Creating your file...
Your file is ready
config.SameSwitchWarn
- Severity
ALERT
- Description
This message occurs when both ports of a disk are found to be attached to the same switch. Higher availability is achieved by cabling disk ports to different switches.
- Corrective Action
Recable one of the indicated ports to a different switch.
- Syslog Message
Disks on port %s:%d are also connected to the same switch at port %s:%d. For availability reasons, they should be connected to two separate switches.
- Parameters
switch1 (STRING): Name of the switch.
port1 (INT): Port number of first connection.
switch2 (STRING): (None).
port2 (INT): Port number of second connection.
