csm.badauthaccess events
Creating your file...
Your file is ready
csm.badAuthAccess
- Severity
NOTICE
- Description
This message occurs when a blade fails an attempt to authenticate as a given peer cluster, and Cluster Session Manager (CSM), which establishes and manages SpinNP sessions between blades in the cluster, denies access of the unauthenticated blade. This could indicate that an interloper is attempting to gain access to the cluster.
- Corrective Action
(None).
- Syslog Message
Access as peer cluster %s was claimed from network address %s, but has not been granted because %s.
- Parameters
clusterUuid (STRING): UUID of the cluster to which the blade claimed to belong.
addrstr (STRING): Remote network address of the blade.
msg (STRING): Reason that access could not be authenticated.
