ctrl.rdma events
Creating your file...
ctrl.rdma.badSystemId
- Severity
NOTICE
- Description
This message occurs when an invalid system ID is found.
- Corrective Action
(None).
- Syslog Message
Invalid system ID %d. High-availability interconnect might not work properly.
- Parameters
name (INT): Invalid system ID value.
ctrl.rdma.heartBeat
- Severity
INFORMATIONAL
- Description
This message logs heartbeat messages.
- Corrective Action
(None).
- Syslog Message
HA interconnect: %s.
- Parameters
hb (STRING): Heartbeat string.
ctrl.rdma.partnerOK
- Severity
INFORMATIONAL
- Description
This message occurs when the partner resumes from pause state.
- Corrective Action
(None).
- Syslog Message
Partner node (system ID: %lld IP address: %s) has resumed from pause state.
- Parameters
sysid (LONGINT): Partner system ID.
ipaddr (STRING): Partner IP address.
ctrl.rdma.partnerPause
- Severity
INFORMATIONAL
- Description
This message occurs when the partner enters pause state.
- Corrective Action
(None).
- Syslog Message
Partner node (system ID: %lld IP address: %s) has entered pause state.
- Parameters
ctrl.rdma.portStateChange
- Severity
INFORMATIONAL
- Description
This message occurs when the state of the HA interconnect link changed frequently in the last hour.
- Corrective Action
Verify that both controllers in the HA pair are operational. For externally connected links, make sure that the interconnect cables are connected properly and that small form-factor pluggable (SFP) modules, if applicable, are seated properly on both controllers. For internally connected links, disable and reenable the links one at a time by using the (privilege: advanced) "system ha interconnect link off" and "system ha interconnect link on" commands. When one link is down on platforms with two available links, HA link redundancy is lost. However, HA services are still working and enabled on the secondary link.
- Syslog Message
HA interconnect: Link to %s changed state %d times in the last hour.
- Parameters
ip (STRING): IP address of the peer.
num_times (INT): Number of times the state changed.
