dbs.ikm events
dbs.ikm
Severity
NOTICE
This message occurs when a Distributed Block Store (DBS) event relating to Internal Key Management (IKM) occurs, such as purging a key.
Corrective Action
(None).
Syslog Message
DBS IKM event %s occurred, type %s, service %u, node %u/%s. drive %u/%s, eventID %u.
evtMessage (STRING): Description of the DBS event, including context details.
evtType (STRING): Type of the original DBS event.
serviceID (INT): Service ID that identifies the associated DBS service. It will be 0 if there is no associated service.
nodeID (INT): Node ID number of the associated node. It will be 0 if there is no associated node.
nodeUuid (STRING): Generated Universal Unique Identifier UUID of the associated node. It displays zeroes if there is no associated node.
driveID (INT): Drive ID number of the associated drive. It will be 0 if there is no associated drive.
driveUuid (STRING): Generated UUID of the associated drive. It diplays zeroes if there is no associated drive.
evtID (INT): DBS event ID number.
evtDetails (STRING): Specific details of the DBS event. It may be a string, in JSON format, or empty.
