dev.driver events
Creating your file...
Your file is ready
dev.driver.throttling
- Severity
NOTICE
- Description
This message occurs when an I/O driver is throttling I/O requests because the underlying controller is overloaded with I/O requests.
- Corrective Action
(None).
- Syslog Message
%s driver unit %d throttling I/O requests due to %s.
- Parameters
devname (STRING): Name of the device.
unit (INT): Unit number of the controller.
reason (STRING): Reason for throttling.
current_throttle_sendq (INT): Current throttle value for send requests
lowest_throttle_sendq (INT): Lowest throttle value for send requests
