device.max events
Creating your file...
Your file is ready
device.max.count.exceeded
- Severity
ERROR
- Description
This message occurs when Data ONTAP® cannot install one or more discovered devices since the device type count is at full capacity.
- Corrective Action
If possible, remove an existing device of the same type so that device installation can proceed. If the failure persists, contact NetApp technical support.
- Syslog Message
Unable to install one or more %s devices discovered on initiator port %s, target port WWNN: %s, WWPN: %s. The device limit (%d) has been reached.
- Parameters
devtype (STRING): SCSI device type.
adapter (STRING): Name of the initiator port discovering the device(s).
wwnn (STRING): World Wide Node Name of the target port exporting the device(s).
wwpn (STRING): World Wide Port Name of the target port exporting the device(s).
limit (INT): Device maximum count.
