dfu.init events
Creating your file...
Your file is ready
dfu.init.noMemory
- Severity
ERROR
- Description
This message occurs when the disk firmware update initialization routine cannot allocate memory.
- Corrective Action
Memory allocation relies on the availability of memory resources in the system. If possible, reduce the workload so that fewer resources are needed. If the failure persists after reducing the workload, contact NetApp technical support.
- Syslog Message
Could not allocate memory for disk firmware update. Requested size=%d bytes.
- Parameters
size (INT): Size (in bytes) of the memory allocation request.
