disk.cksum events
Creating your file...
disk.cksum.bno.verifyFailed
- Severity
ALERT
- Description
This message occurs when the system detects a block number mismatch during disk checksum verification. The expected Virtual Block Number (VBN)/Disk Block Number (DBN) is not the same as the stored VBN/DBN from the checksum entry, indicating that the block is read from the wrong location.
- Corrective Action
(None).
- Syslog Message
Block number mismatch on WRITE VERIFY: Disk %s, expected_dbn = %u, stored_dbn = %u, expected_vbn = %llu, stored_vbn = %llu, Volume %s, FileId %d, Block #%llu.
- Parameters
diskName (STRING): Name of the device.
expected_dbn (INT): Expected physical disk block number.
stored_dbn (INT): Physical disk block number stored in the checksum entry.
expected_vbn (LONGINT): Expected volume block number.
stored_vbn (LONGINT): Volume block number stored in the checksum entry.
vol (STRING): Volume name.
fileid (INT): File ID.
block (LONGINT): File block ID.
