disk.iorecoverederror events
Creating your file...
disk.ioRecoveredError.pfa
- Severity
ERROR
- Description
This message occurs when a disk determines that it will fail shortly. This occurs when a threshold internal to the disk indicates that a failure is imminent.
- Corrective Action
To avoid an uncontrolled failure, replace the disk as soon as possible. If the disk is a member of a RAID volume, the disk will be failed by RAID when this error occurs on a RAID I/O and the RAID group is not in degraded mode.
- Syslog Message
Recovered error predictive failure alert on disk %s: op %s sector %llu %s - %s (%x %x %x %x)
- Parameters
diskName (STRING): Name of the disk.
op (STRING): I/O operation being performed.
sector (LONGINT): Sector where the error was detected.
senseInfo (STRING): Sense data.
disk_info (STRING): Static description of events on the disk.
sense_key (INTHEX): Actual sense key.
sense_code (INTHEX): Actual sense code.
qualifier (INTHEX): Actual sense code qualifier.
fru_failed (INTHEX): Actual FRU code.
disk_information (STRING): Formatted information about the disk. This includes the disk's vendor, model, firmware revision, and serial number.
disk.ioRecoveredError.reassign
- Severity
NOTICE
- Description
This message occurs when a disk automatically reassigns a sector on a disk.
- Corrective Action
(None).
- Syslog Message
Recovered error on disk %s: op %s sector %llu %s - %s (%x %x %x %x) %s
- Parameters
disk.ioRecoveredError.retry
- Severity
INFORMATIONAL
- Description
This message occurs when a recovered error is detected on a disk.
- Corrective Action
(None).
- Syslog Message
Recovered error on disk %s: op %s sector %llu %s - %s (%x %x %x %x) (%d) %s
- Parameters
ETime (INT): Time, in milliseconds, from when the command was first issued until this I/O operation failed.
