disk.reservedelay events
Creating your file...
Your file is ready
disk.reserveDelay
- Severity
NOTICE
- Description
This message occurs when a SCSI reservation command has a longer latency than expected during takeover. This delay could cause a system outage in which case the disk should be removed to prevent further problems. .
- Corrective Action
If you see this message before an outage on takeover, remove the specified disk.
- Syslog Message
The disk reservation command sent to %s has taken longer than expected: %d msecs during takeover.
- Parameters
diskName (STRING): Name of the device.
elapsed_time (INT): Number of milliseconds for the command to complete.
