diskown.autoassignproblem events
Creating your file...
Your file is ready
diskown.AutoAssignProblem
- Severity
ERROR
- Description
This message occurs when Data ONTAP® attempts to assign a disk automatically, but the request fails. The failure could be due to a disk error or a user simultaneously assigning the disk to a storage system.
- Corrective Action
Use the "disk show -v" nodeshell command to determine the status of the disk. Use the "storage disk assign" command to assign the disk.
- Syslog Message
Automatic assigning failed for disk %s (S/N %s). Reason: %s
- Parameters
diskname (STRING): Name of the disk.
serialno (STRING): Serial number of the disk.
reason (STRING): Reason for the failure.
