diskown.completion events
Creating your file...
Your file is ready
diskown.completion.timer.reEnabled
- Severity
INFORMATIONAL
- Description
This message occurs when the COMPLETION events from sanown layer remain after an aggregate is migrated form a source to a destination. Typically the events are enabled automatically, and if that doesn't happen with in a certain amount of time, the system reenables the COMPLETION events and logs this message.
- Corrective Action
(None).
- Syslog Message
Sanown completion event timer reenabled after a giveback.
- Parameters
(None).
