diskown.diskhaswronginfo events
Creating your file...
diskown.diskHasWrongInfo
- Severity
ERROR
- Description
This message occurs when the disk ownership information on a disk does not belong to the disk that it was read from. This could be a result of a read going to the wrong disk or a prior write intended for some other disk getting written to the disk.
- Corrective Action
On the controller that owns the disk, use the "storage disk assign" command to rewrite the ownership information to the disk.
- Syslog Message
Disk %s (S/N %s) has ownership information for disk %s (S/N %s) on it.
- Parameters
diskname (STRING): Name of the disk from which the ownership information was read.
serialno (STRING): Serial number of the disk from which the ownership information was read.
infoForDiskname (STRING): Name of the disk that the ownership information is for.
infoForSerialno (STRING): Serial number of the disk that the ownership information is for.
