diskshelf.unsupported events
diskShelf.unsupported
Severity
ALERT
This message occurs when ONTAP® software detects an unsupported disk shelf.
Corrective Action
Verify that the disk shelf attached is supported by the version of ONTAP running on the storage controller. If the disk shelf is supported, replace the disk shelf module.
Syslog Message
Disk shelf %s (%s) is unsupported.
device (STRING): Device address of the disk shelf.
product_id (STRING): Product ID of the disk shelf.
