fmmb.blobnotwritten events
Creating your file...
Your file is ready
fmmb.BlobNotWritten
- Deprecated
Deprecated as of version 9.2.
- Severity
ALERT
- Description
This message occurs when a mailbox 'blob' write operation to the on-disk mailbox data structure fails. A 'blob' is a piece of data that has been stored for a non-high availability (HA) Data ONTAP® subsystem in the HA mailbox.
- Corrective Action
If the blob ID is "3" and this is a two-node cluster, use the 'cluster ha modify -configure' command to unconfigure HA and then reconfigure it.
- Syslog Message
(None).
- Parameters
blob_id (INT): 'blob' ID.
owner (STRING): Owner of the blob, either PARTNER or LOCAL.
reason (STRING): Reason for the problem.
