ha.panicinforcvbadvrsn events
Creating your file...
ha.panicInfoRcvBadVrsn
- Severity
NOTICE
- Description
This message occurs when the version of the panic information received from the high-availability (HA) partner is not equal to the expected version. The receiving node will discard this panic information message. A takeover might still occur if the local node detects that its HA partner is down by other means, and takeover of the panicking node is allowed.
- Corrective Action
(None).
- Syslog Message
Panic information message received from the HA partner is the wrong version. Expected version: %u. Received version: %u. Partner name: %s. Partner system ID: %llu.
- Parameters
expected_version (LONGINT): Expected version of the panic information.
received_version (LONGINT): Received version of the panic information.
partner_name (STRING): Name of the HA partner.
partner_systemid (LONGINT): System ID of the HA partner.
