hotplug.insert events
hotplug.insert.badCard.type
Severity
ERROR
This message occurs when the module type does not match the system's record for this slot.
Corrective Action
Use a replacement module of the same type.
Syslog Message
%s module insertion failed in slot %s of node %s because the module type does not match the system's record for this slot.
card (STRING): Name of the module.
slot (STRING): Number of the slot.
node (STRING): Name of the node.
hotplug.insert.badCard.ver
Severity
ERROR
This message occurs when the module revision does not match the system's record for this slot.
Corrective Action
Use a replacement module of the same board revision.
Syslog Message
%s module insertion failed in slot %s of node %s because the module revision does not match the system's record for this slot.
hotplug.insert.illegal_card
Severity
NOTICE
This message occurs when the module inserted is not supported.
Corrective Action
Use vendor-approved modules.
Syslog Message
%s module insertion failed in slot %s of node %s because the module is not supported.
Severity
ALERT
This message occurs when link on module fails to initialize after module is powered on.
Corrective Action
Reinsert the module and try command again. If problem persists, contact NetApp technical support for assistance.
Syslog Message
%s module insertion failed in slot %s of node %s because the link on module failed to initialize.
hotplug.insert.no_power_up
Severity
ALERT
This message occurs when a module does not initialize after it is powered on.
Corrective Action
Reinsert the module and try the command again. If the problem persists, contact NetApp technical support for assistance.
Syslog Message
%s module insertion failed in slot %s of node %s because module failed to initialize.
hotplug.insert.success
Severity
NOTICE
This message occurs when module insertion is successful.
Corrective Action
(None).
Syslog Message
%s module insertion is successful in slot %s of node %s.
