ipmultipath.init events
Creating your file...
ipmultipath.init.badChksumType
- Severity
ERROR
- Description
This message occurs during IP Multipath session initialization, when an INIT packet with an unknown checksum type is received.
- Corrective Action
The two end points are possibly running incompatible versions of Data ONTAP®. Run identical/compatible versions of Data ONTAP on the two end points and try again.
- Syslog Message
Unknown checksum type (%d) in IP Multipath INIT packet.
- Parameters
chksum_type (INT): Checksum type received.
ipmultipath.init.badVersion
- Severity
ERROR
- Description
This message occurs during IP Multipath session initialization, when an INIT packet with an unknown version number is received.
- Corrective Action
- Syslog Message
Unknown version (%d) in IP Multipath INIT packet.
- Parameters
version (INT): Version number received.
