iscsi.loginipnotauthorized events
Creating your file...
Your file is ready
iscsi.loginIpNotAuthorized
- Severity
NOTICE
- Description
This message occurs when the system rejects an iSCSI login attempt because it originates from an unauthorized IP address.
- Corrective Action
Run 'iscsi security show -address-ranges' to see if the initiator IP address has been added to the list of permitted IP addresses from where iSCSI logins are allowed.
- Syslog Message
iSCSI login authorization failure. Initiator %s attempted to log in on Vserver %s, LIF %s from IP address %s
- Parameters
initiator_name (STRING): Name of the initiator that attempted to login.
vserver (STRING): Name of the vserver to which the unauthorized login attempt is made.
lif (STRING): Name of the LIF where the login was attempted.
initiator_ip_address (STRING): Source IP address of the initiator that attempted to login.
