ktls.cnxnhandshakelimit events
Creating your file...
Your file is ready
ktls.cnxnHandshakeLimit
- Severity
NOTICE
- Description
This message occurs when the concurrent TLS connection handshake limit is reached. Any new TLS connection request will fail and an error status will be returned.
- Corrective Action
Reduce the encrypted connection load on ONTAP to avoid reaching the maximum concurrent TLS handshake limit.
- Syslog Message
ONTAP reached the maximum limit of %d concurrent TLS connection handshakes. If this limit is reached, subsequent TLS connections will fail.
- Parameters
maxTLSConnHandles (INT): Maximum number of concurrent TLS connection handshakes.
