ONTAP EMS reference
master.demote events
master.demote.cm.committed
Severity
NOTICE
This message occurs when the associated node successfully updates the global database to demote current cluster master. As a result, a new cluster is promoted.
Corrective Action
(None).
Syslog Message
Service ID %u on node ID %u (UUID: %s) successfully updated database to demote cluster master with sequence number %u and service ID %u.
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID of the associated node.
sequenceNumber (INT): Sequence number of the cluster master last known by this node.
lastKnownClusterMasterServiceID (INT): Service ID number of the cluster master last known by this node.
