mdb.exit events
mdb.exit
Severity
EMERGENCY
This message occurs when the management process exits to recover from a database error.
Corrective Action
If the problem persists, contact NetApp technical support for assistance.
Syslog Message
MDB %s process exit due to "%s". Error code: %d (%s).
name (STRING): Name of the M-Host process using the management database.
table_or_operation (STRING): Database table name or operation that encountered the error.
error_code (INT): Numeric error code reported by the management database.
error_msg (STRING): Error message reported by the management database.
