mgmtgwd.schedsnap events
Creating your file...
mgmtgwd.schedSnap.createFail
- Severity
ERROR
- Description
This message occurs when the system fails to create a Snapshot(tm) copy for the given volume.
- Corrective Action
Correct the problem based on the reason specified. If the error persists, contact NetApp technical support.
- Syslog Message
Skipping creation of scheduled Snapshot copy '%s' on volume '%s' on vserver '%s' for schedule '%s' prefix '%s' (reason: %s)
- Parameters
snapshotName (STRING): Name of the Snapshot copy.
volumeName (STRING): Name of the volume.
vserverName (STRING): Name of the virtual server.
scheduleName (STRING): Name of the Snapshot policy schedule.
prefixName (STRING): Name of the prefix associated with the Snapshot policy schedule.
reason (STRING): Reason for the failure.
mgmtgwd.schedSnap.createSkip
- Severity
ERROR
- Description
This message occurs when a scheduled Snapshot(tm) copy for a volume is skipped because there is a conflicting operation being performed on the volume.
- Corrective Action
- Syslog Message
Skipping creation of scheduled Snapshot copy for volume "%s" on Vserver "%s" using policy "%s". Reason: %s.
- Parameters
vserverName (STRING): Name of the Vserver.
snapshotPolicy (STRING): Name of the Snapshot policy.
reason (STRING): Reason that the scheduled Snapshot copy was skipped.
appUuid (STRING): UUID of the Application.
