mlm.tapemc events
Creating your file...
mlm.tapemc.lun.discovery
- Severity
INFORMATIONAL
- Description
This message occurs when the system discovers a new tape or media changer logical unit (Tape/MC LUN) reported by a tape library.
- Corrective Action
(None).
- Syslog Message
New %s LUN %s (S/N: %s) was discovered on initiator port %s at tape library target port WWNN: %s, WWPN: %s.
- Parameters
deviceType (STRING): Type of LUN device.
deviceName (STRING): Name of the Tape/MC LUN.
serialno (STRING): Serial number of the LUN.
adapterName (STRING): Name of the initiator port discovering the LUN.
wwnn (STRING): World Wide Node Name(WWNN) of the library target port exporting the new LUN.
wwpn (STRING): World Wide Port Name(WWPN) of the library target port exporting the new LUN.
mlm.tapemc.lun.noInit
- Severity
ERROR
- Description
This message occurs when the initialization sequence for a tape or media changer logical unit (LUN) fails.
- Corrective Action
An expected LUN might be missing from the configuration. Information about the path to the LUN might be unknown but the product information in the log may help identify the missing LUN. Check the device LUN configuration settings.
- Syslog Message
%s device %sL%d failed LUN initialization sequence at phase %s.
- Parameters
deviceName (STRING): Name of the device on which the LUN initialization fails.
lunid (INT): LUN ID of the device on which LUN initialization fails.
lunInitPhase (STRING): Failing LUN initialization phase.
mlm.tapemc.lun.PathAdded
- Severity
INFORMATIONAL
- Description
This message occurs when a new path is added for a tape or media changer logical unit (Tape/MC LUN).
- Corrective Action
(None).
- Syslog Message
%s LUN '%s' (S/N: %s) is now connected on initiator port %s through %s's target port: WWNN: %s, WWPN: %s at LUN ID: %d.
- Parameters
adapterName (STRING): Name of the adapter used to access the LUN.
libraryName (STRING): Name of the library.
wwnn (STRING): World Wide Node Name(WWNN) of the library target port.
wwpn (STRING): World Wide Port Name(WWPN) of the library target port.
LUNID (INT): LUN ID to which a path was added.
mlm.tapemc.lun.PathRemoved
- Severity
INFORMATIONAL
- Description
This message occurs when a path to this tape or media changer logical unit (Tape/MC LUN) is removed.
- Corrective Action
(None).
- Syslog Message
The %s LUN '%s' (S/N: %s) is no longer available on initiator port %s through %s's target port: WWNN: %s, WWPN: %s.
- Parameters
mlm.tapemc.lun.removed
- Severity
NOTICE
- Description
This message occurs when the last path to a tape or media changer logical unit (Tape/MC LUN) is removed.
- Corrective Action
(None).
- Syslog Message
The %s LUN '%s' (S/N: %s) is no longer visible to this node.
- Parameters
mlm.tapemc.path.discovery
- Severity
INFORMATIONAL
- Description
This message occurs when the system discovers a new tape or media changer logical unit (Tape/MC LUN) path.
- Corrective Action
(None).
- Syslog Message
A new Tape/MC path was discovered: initiator port %s is now connected to tape library %s's target port: WWNN: %s, WWPN: %s. There are %d LUNs visible on this target port.
- Parameters
adapterName (STRING): Name of the initiator port discovering the Tape/MC LUN.
libraryName (STRING): Name of the tape library.
count (INT): Number of LUNs visible on this port.
