ONTAP EMS reference
ndmp.ctrl events
ndmp.ctrl.on.e0m
Severity
ALERT
This message occurs when the IP address of the logical interface (LIF) that hosts the NDMP control connection is hosted on maintenance port "e0M". This port does not provide sufficient bandwidth for NDMP.
Corrective Action
Ensure that the LIF is moved out of port "e0M" and hosted on a high bandwidth port, or use a LIF hosted on a high bandwidth port for the control connection.
Syslog Message
NDMP control connection is established on "%s" which is hosted on port "%s". This is a low bandwidth port and might impact performance.
lif_addr (STRING): Local control connection IP address.
lif_port (STRING): Port on which the control connection IP address is hosted.
