nfs.client events
Creating your file...
Your file is ready
nfs.client.cache.modify.err
- Severity
ERROR
- Description
This message occurs when an NFS connected client's cache settings are changed using the REST API "/api/protocol/nfs/connected-client-settings", but the value is not updated in the network component. This might lead to the cache refresh behavior not working as expected.
- Corrective Action
Use the REST API PATCH "/api/protocol/nfs/connected-client-settings" to update the value.
- Syslog Message
Connected-clients cache settings could not be updated. Error: %s.
- Parameters
reason (STRING): Reason for the failure.
