noderun.login events
Creating your file...
Your file is ready
noderun.login.success
- Severity
INFORMATIONAL
- Description
This message occurs when a cluster user successfully logs in to the node using the 'run' command.
- Corrective Action
(None).
- Syslog Message
'%s' logged in from cluster: '%s'.
- Parameters
user (STRING): Name of the user who logged in to the node.
cluster (STRING): Cluster name from where the user logged in to the node.
