nvme.ssd events
Creating your file...
Your file is ready
nvme.ssd.attach.error
- Severity
ERROR
- Description
This message occurs when the NVMe drive encounters an error before the drive is reported to upper layers. The drive will not be discovered, and will not appear in sysconfig output.
- Corrective Action
The drive could not be attached. Remove or replace the drive.
- Syslog Message
NVMe SSD encountered error: "%s" on slot %d. Could not attach drive.
- Parameters
error (STRING): Type of error that occurred.
slot (INT): Slot number of associated NVMe SSD.
