nvmf.graceperiod events
Creating your file...
nvmf.graceperiod.active
- Severity
ALERT
- Description
This message occurs daily while the NVMe over Fabrics (NVMe-oF) protocol is in use and the license grace period is active. NVMe-oF functionality requires a license in this version of ONTAP® software after the license grace period expires.
- Corrective Action
Contact your sales representative to obtain an NVMe-oF license and add it to the cluster, or remove all NVMe-oF configuration from the cluster.
- Syslog Message
The NVMe-oF feature requires a license in this version of ONTAP. NVMe-oF functionality will be disabled in %d days (%s) unless a license is added to the cluster.
- Parameters
days_remaining (INT): Days until the license grace period expires.
expiration_date (STRING): Date the license grace period expires.
object_type (STRING): Type of resource object under notification. For this EMS, the object_type is CLUSTER.
object_uuid (STRING): UUID of the resource object. For this EMS, the UUID is that of the cluster.
nvmf.graceperiod.expired
- Severity
ALERT
- Description
This message occurs when the NVMe over Fabrics (NVMe-oF) license grace period expires and NVMe-oF functionality is disabled. NVMe-oF functionality requires a license in this version of ONTAP® software after the license grace period expires.
- Corrective Action
Contact your sales representative to obtain an NVMe-oF license, and then add it to the cluster.
- Syslog Message
The NVMe-oF feature requires a license in this version of ONTAP and the grace period has expired. NVMe-oF functionality will be disabled until a license is added to the cluster.
- Parameters
nvmf.graceperiod.start
- Severity
ALERT
- Description
This message occurs when an NVMe over Fabrics (NVMe-oF) configuration is detected during upgrade to ONTAP® 9.5 software. NVMe-oF functionality requires a license in this version of ONTAP after the license grace period expires.
- Corrective Action
- Syslog Message
- Parameters
