nvram.flash events
Creating your file...
Your file is ready
nvram.flash.spare.low
- Severity
ALERT
- Description
This message occurs periodically when the capacity of the NVRAM flash memory spare blocks is low, before it becomes critically low. This issue typically indicates that the NVRAM hardware is approaching the end of its service life and should be replaced soon.
- Corrective Action
Contact NetApp technical support for replacement assistance.
- Syslog Message
NVRAM flash memory spare capacity is low: %s.
- Parameters
problem (STRING): Information about the NVRAM flash memory spare blocks whose capacity is low and about its condition.
