rlm.firmware events
Creating your file...
rlm.firmware.upgrade.reqd
- Severity
NOTICE
- Description
This message occurs when the Remote LAN Module (RLM) firmware version and the Data ONTAP® software version are incompatible and cannot communicate correctly about a particular capability.
- Corrective Action
For more information about upgrading your firmware, check your support provider's web site or knowledgebase. After the RLM is running the new firmware, this message should no longer occur. If the problem persists or you need further assistance, contact NetApp technical support.
- Syslog Message
The RLM firmware %s is incompatible with Data ONTAP for %s.
- Parameters
current_rlm_fw_version (STRING): Current firmware version on the RLM.
capability (STRING): RLM capability needed by Data ONTAP.
rlm.firmware.version.unsupported
- Severity
NOTICE
- Description
This message occurs when the firmware on the Remote LAN Module (RLM) is not an official release and must be upgraded.
- Corrective Action
- Syslog Message
The RLM firmware version %s is not an official release.
- Parameters
